sla 110 wont start
Old Aug 2, 2011 | 12:49 PM
mspags56's Avatar
Default sla 110 wont start
I have a sla110 that will not turn over,when you push starter button,I charged battery,and also tried to jump selonoid.Where do i start
Old Aug 2, 2011 | 12:55 PM
Jaster94's Avatar
ok, is there a fuse on the positive side of the battery cable? if so, is it intact?
i presume your quad is a one speed and doesn't shift gears, SO, listen very closely when you apply the left hand brake. you should hear a "tink" at the handlebar and then obviously the brake light should become illuminated. brake lights may work or not, but the brake switch SHOULD. then you should be able to use the starter button or try jumping the solenoid.
another thing to check for is if the remote, if applicable, is working correctly. the umbilical cord shutdown, if applicable, would need to be checked for proper operation--make sure it's plugged in all the way....get back with us with details....thanks.. p.s. when watching a post for replies, refresh the page every minute or so to see if someone has replied. thanks again.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
