fans
Old Dec 15, 2011 | 09:16 AM
blain's Avatar
Default fans
hi guys i have a 2005 250 baja wilderness there are two fans on it but are burned out i know where to get them but most say fans for water cooled engine i don; have that.theres just two fans anyone no if some came with just fans only and would that cause my pipe to turn red all the time
Old Dec 15, 2011 | 10:41 AM
scootergptx's Avatar
Supersock
Hired Gun!
Doesn't that have an oil cooler? Seems I've seen a few that did.
Wouldn't have anything to do with your pipes getting that hot. I'd check the fuel mixture.
Old Dec 15, 2011 | 10:47 AM
blain's Avatar
Default oil cooler
how would i check to find out that don;t no much about and what dose the oil cooler do if it dos have it thank you
Old Dec 15, 2011 | 10:56 AM
Supersock
Hired Gun!
Gonna be in front of the motor. This is from another quad, but should look something like a small radiator.
I don't know that yours has one, but if it's got fans and air cooled my guess is you have a cooler.
Old Dec 15, 2011 | 11:34 AM
blain's Avatar
thanks i;;l check
Old Dec 15, 2011 | 11:42 AM
blain's Avatar
Default cooler
I justed checked it dosn;t have that do you no where i can find on internet the hole diagram of the machine
Old Dec 15, 2011 | 11:45 AM
Supersock
Hired Gun!
Can you post a picture of where the fans are on yours?
Old Dec 15, 2011 | 11:59 AM
blain's Avatar
Default fans
not really camera is broke theres two fans in a steel case kind of mounted to frame right in front of the motor about a foot away from the motor i don;t see anything where lines go into motor for a cooler would it be just the fans that keep it cool. i can;t seem to find a diagram of all the atv
Old Dec 15, 2011 | 04:05 PM
DennyRoark's Avatar
The fans help cool the engine at low speeds and idle. I'd replace 'em. As for your pipe getting red, you need to clean out your spark arrestor screen, very soon! Mine (Marshin, very similar) has a bolt in the bottom of the muffler you take out. Then you plug the tail pipe and gun the motor a few times. You are essentially back flushing the spark arrestor. On my Yamaha, it has three allen bolts you take off the back of the muffler. The screen comes out with the tail pipe and you clean it by hand. Do this very soon! ( I killed a chainsaw a few years back this way) The back pressure from the exhaust will damage your engine! If you don't have a spark arrestor, your muffler is probably plugged up.
Denny
Old Dec 16, 2011 | 07:03 AM
blain's Avatar
Default fans
thank you so much for the info so do you think all that cools my motor is the two little fans i don;t see anything else there other said a cooler on it maybe but nothing there.
