hard start 110cc
Old Jan 25, 2012 | 07:19 PM
chineseatv's Avatar
Default hard start 110cc
well i have the falcon 110cc
ive rode it a few times.. and to get the thing to start its a pain but once it runs it runs perfect.. but if you let it stall it will drain the battery trying to start it.. then i drag it into the garage and put a battery charger on it and get it to fire up..
im in Michigan so its for sure cold.. maybe i just suck with choking it.. ether i flood it or dont seem to get enough fuel...
i doubt the choke is why i cant get it to fire up..this isnt my first time around a small engine..
any suggestions?? only thing i could think of is maybe a dirty carb?
or maybe the coil is going bad?? but once i clean the plug ill have good spark everytime.
thanks!
Old Jan 25, 2012 | 07:43 PM
LouisianaATV's Avatar
thanks!
Could be most any of the things you listed. My guess is that it isnt in your carb considering it runs well when it warms up. I would say to try a valve adjustment. Valves should be set at .004. This should take care of it.
Old Jan 25, 2012 | 07:46 PM
chineseatv's Avatar
its hard to start cold or hot...
have directions on how to adjust valves?
thanks
i did just have the motor completely apart well kind of..
Old Jan 25, 2012 | 07:49 PM
thanks
VALVE ADJUSTMENT ON A CHINESE QUAD - YouTube
pictures are worth a thousand words. Give this a shot.
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Dame0927
Oct 29, 2015 10:13 PM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
