what could it be?
Old Feb 6, 2012 | 02:58 PM
Hippie Robert Nixon's Avatar
Default what could it be?
when i start my bashan 200cc it vibrates really bad and has a really loud rattleing comeing from the engine any idea?
Old Feb 6, 2012 | 04:22 PM
Jaster94's Avatar
have you checked the motor mounts? the bushings could be worn down to nothing. do you reckon it's mechanical? as in the engine knocking instead of rattling? hopefully the valves are not chattering. without a video for sound, i'm unsure. just a couple of shots in the dark.
Old Feb 6, 2012 | 04:52 PM
to behonest am mechanically useless ill record it as as soon as i can and post it thanks
Old Feb 6, 2012 | 05:05 PM
Jaster94's Avatar
. plenty of oil in crankcase? what's the oil smell like/look like? burnt or normal? start the engine and let it idle, take a close look at the motor mounts, the exhaust pipe, and other peripherals that can vibrate and make noise. don't hesitate to feel around with your gloved hands. just don't burn yourself. that'd suck. i'm sure we can narrow this down for you fairly quickly.
Old Feb 7, 2012 | 06:52 AM
just started it got to keep the revs up as it wont idle and dies after a few seconds. seems theys oil appearing on the right foot plate so guessing theres a leak/its spitting
Old Feb 7, 2012 | 07:32 AM
as u can see on the foot plate theys oil
Bashan 200s3 quad loud noise - YouTube
Old Feb 7, 2012 | 12:48 PM
irishdude's Avatar
sounds like its coming from the crank case
Old Feb 7, 2012 | 09:21 PM
could this be an easy fix or be a nightmare of a job?
Old Feb 8, 2012 | 11:22 AM
irishdude's Avatar
well first figure out where exactly the noise is coming from because something kinda similar happened to mine except it was a more high pitched noise. i too off the exhaust, tapped it with a hammer a few times and a load of **** fell out and the noise disappeared. but if its definitely leaking oil then it cant be good anyway you look at it....
Old Feb 8, 2012 | 09:12 PM
cheers for all the info alot more forward then i was. was simplely clue less. going to have a good inspection with help of a mechanic mate over the weekend
