Yamoto Electrical Problem
Old Apr 20, 2012 | 03:20 PM
TheValater's Avatar
Default Yamoto Electrical Problem
Hi iv'e purchased a yamoto 200cc quad bike and i seem to have a major problem with the starter. When i bought the quad the chap said that the starter was jammed but i took it off the quad bike and had the starter tested and the starter is spinning lovely. When the starter is put back onto the qaud there seem to be nothing not even a clicking or anything. Ive put a new battery on the bike to to see and still nothing but the quad bike will bump start fine tho. Any ideas please
Old Apr 20, 2012 | 11:12 PM
LynnEdwards's Avatar
Electrical Expert
When you push on the start button, and all the safety interlocks are satisfied, the starter solenoid should close (going "click") which connects the battery directly across the starter, making it spin.
So do I understand you correctly: There is no "click" from the solenoid when you push the start button? Have you tried jumping across the solenoid? Generic procedure follows:
Find the postive battery terminal, and follow the big fat red wire to the starter
solenoid screw terminal. Follow the other starter solenoid screw terminal to the
starter motor.
Turn the ignition switch to the "on" position, and set all kill switches to the
"run" position.
Important: For the following test make sure your quad is in neutral and
the parking brake is set. You are about to bypass all safety interlocks and
connect the battery directly across the starter motor. If the quad should start
up you don't want the quad to take off unexpectedly...
Now take a screwdriver and use the shank to short those two screw posts on the
starter solenoid together. Some sparking is OK.
Does the starter turn?
Old Apr 21, 2012 | 04:46 AM
TheValater's Avatar
ill give this a try and see what happens. Thanks Lynn Edwards for the information ill let you know either way if it works or not there cant be much wrong with it because she goes on a bump start ok. I must say tho she is very fast machine for a 200 anyway thanks for the info ill get back to you cheers
Old Apr 23, 2012 | 04:42 PM
TheValater's Avatar
Default Electrical Sorted
Hi lynn Edwards i have sorted out the starting problem there was a wire come off in the start button i soldered it back on to the terminal and it is now working fine starts first time. Im happy now thanks for the info the other day ill keep in touch meny thanks
Old Apr 23, 2012 | 11:25 PM
Electrical Expert
Looks like you jumped way ahead of the procedure and solved it on your own .
Congrat's on a good job..
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
