Keep blowing head gaskets
Old Apr 26, 2012 | 07:47 AM
Dyna9874's Avatar
Default Keep blowing head gaskets
My daughter has a 2002 50cc dinli ATV. It keeps blowing head gasskets. I have checked the deck surface and cylinder head for warpage and there doesn't appear to be any. I am at a loss. Is it possible the bike is running to lean. It had oil injection system but have since gone to a 32:1 premix. Any help would be greatly appreciated.
Old Apr 26, 2012 | 07:08 PM
Jaster94's Avatar
are you torquing the bolts after a gasket change out?
Old Apr 27, 2012 | 12:21 PM
Dyna9874's Avatar
I torqued the head bolts to 12 lbs/ft. But they were a lot tighter than that when I removed them the first time. Is it possible that the threads have pulled and are not letting the head tighten down enough?
Old Sep 21, 2012 | 08:39 PM
fixermaybe's Avatar
after you replace the gasket, torque the head bolts down to specs. Then run it and let it heat up and cool down then retorque....sometimes when it expands and contract it can loosen the tourque...if that makes sense....whenever I rebuild an engine I always retorque after I run it and get it up to temp.....
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
