Tao tao rear barring clacking
Old May 22, 2012 | 09:27 AM
High_Boost's Avatar
my shock bushings had a ton of slack from the day I bought it..
nothing good about the shocks at all.. no damping, the springs are super stiff, the bushings are garbage
another thing that has been mentioned is to check all the bolts..
what I found on mine is the suspension bolts all have castle nuts and cotter key to hold them, the problem is the cotter key hole is drilled too low. Because of this the castle nuts unscrew a bit before the cotter key stops them.. this causes loosness in the stearing and suspension.
To stop this I got a bag of washers at the hardware store (10mm?) and added 1 under each of the suspension nuts (all the tie rodes, etc.) then I tightened them up and put the cotter keys back in. It tightened the suspension a ton.
Before I did this the steering was always clunky and loose, I could turn the handle bars at least an inch before the wheels would move and now there is no slack.. a great cheap upgrade!
I have also had my exhaust come loose where it mounts under the seat, you might check that as well.
Old Jun 5, 2012 | 09:23 PM
Richard Graham Poster's Avatar
Originally Posted by 95wolv
I have heard those Chinese chains stretch like a rubber band, could be you are hearing links rattling over the sprockets, make sure the tension is set right, if the chain is sloppy, and cant be adjusted anymore, get a good quality chain and replace it.
The chains on these chinese bikes is actually #40 machine chain and it only comes in 10 foot lengths so you get 2 full chains out of that.
Also, on our 150, the right side lower engine mounting bolt shook loose and fell out while riding causing the torq to pull the engine into a slight leaning position. Then the sprocket started clicking and then it would throw the chain which then caught in the rear end and snapped. The chain then clicked and fell off again, not knowing the engine was leaning to the side. We pried the engine back up and replaced the engine mounting bolts with good quality ones and now it's better than new. The sprockets are aligned again and the chain runs smooth and everything just feels stronger.
And I should add when this bike was new, all the rear end bolts were very loose and needed tightening. The whole rear axle was loosely moving around.
Old Jun 6, 2012 | 08:39 AM
High_Boost's Avatar
mine uses a 420, but they are super cheap
when I changed my sprockets my new chain cost me ~$8 and it came in any length I wanted, I just googled it and bought it off the internet from some random bike parts store
Old Jun 7, 2012 | 11:25 PM
Originally Posted by gcharlie
Can someone help me i just brought a tao tao 110 cc Atv for my 7 year old about a week ago i change the oil and spark plug when i just got it in after 3 days of slow rideing i began to here a clacking noice in the rear .It sounds like a barring in the rear i greased the chain good and tryed to grease what i can .But there no kind of grease Surts any where on the rear axal can any one tell me what should i do.And do u know if there any other fluids i need to check besides the oil .
Mine was doing the same thing after a few rides. I was also afraid it was the bearings. It was an easy fix. Adjusted chain tension (1 inch of up and down play) and used moly based chain lube on the chain. Make sure all sides of the chain are completely wet with lube. This stopped my clacking/grinding noise completely.
Ashley S
Feb 18, 2024 08:56 PM
STLyamwar
Jul 25, 2020 04:44 AM
panicmanic
Aug 25, 2015 09:10 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
