2008 quad has clutch problems 110cc
Old Jun 27, 2012 | 01:50 PM
Mr.Firemouth's Avatar
Default 2008 quad has clutch problems 110cc
I got the Carb cleaned and the quad lubed and found out the clutch is slipping. What is the proper procedure to tighten the clutch? Also is there a process to replace the clutches?
Attached Thumbnails 2008 quad has clutch problems 110cc-img00028-20100916-1734.jpg
Old Jul 11, 2012 | 05:40 PM
No replies huh?
Old Jul 13, 2012 | 12:34 PM
High_Boost's Avatar
best I can do from memory is on the right side of the engine there should be a nut (14mm?) with a slotted scew coming thru it..
hold the screw still with a screw driver and loosen the jam nut, be careful not to damage the screw (use a big enough screwdriver so it doesnt get mangled)
then you turn the slotted screw to the right ~1 turn or so untill it is loose, then you turn it to the left left untill it gets tight, then back it off a half a turn
this should be the correct adjustment.. hold the screw still with the screw driver and retighten the jam nut
fyi, if it is to the right too much it makes it too tight (even though the screw is loose) it will be hard to shift, etc... if it is too tight it loosens it
hth
Land_shark1
Jul 10, 2015 12:53 AM
FWhitt
Jun 13, 2015 02:22 PM
kevbowe
Jun 1, 2015 01:17 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
Jiggypete
May 30, 2015 07:55 AM
