Tao Tao 150 HELP! Can't get started after carb clean
Hi everyone. I recently posted on here and received help and am hoping to do the same again. I had a problem with my atv bogging and was told to clean the carb. I did that and ended up with the same problem so I just took it off to clean it again. The jets were clogged and so I thought I solved the problem. After I put the carb back on (the exact same way I did so before) the atv will not start. When I push the starter button it sounds like it wants to go but maybe isn't getting gas? When I push the throttle to give it has it makes a noise as if I'm pushing it but no gas is going through. I've tried emptying the gas and re putting it in and also have checked to make sure everything is the way it should be and it seems to be exactly right. There is not a gas shut off switch so I know that it is not that. Thanks for any help.
Jun 10, 2015 12:45 AM
