Chinese 110 atv ( Head full of oil)
Old Jul 13, 2012 | 08:57 PM
jwhitworth261's Avatar
Default Chinese 110 atv ( Head full of oil)
Hello. I just purchased a Asun 110 and I can not get it to start. I have a brand new carb and it has fire. I thought maybe it was a valve issue so I pulled the small round inspection covers off the head and alot of oil ran out of the lower valve near the exhaust pipe. Im not sure if this is normal. PLEASE HELP! Thanks
Old Jul 13, 2012 | 10:52 PM
Jaster94's Avatar
was your spark plug wet with gasoline? if you got fire, all you lack is fuel and air....it ought to be sucking air, so that leaves us with a possible fuel delivery issue. let's get you to check that out. so, the float bowl, open drain on that to see if you got fuel there at the carb. if your spark plug ain't wet with gasoline, then your jets may be plugged. i know you said you had a new carb, but you could've sucked in solids and debris from the tank. got a fuel filter? petcock valve open? no fuel line obstructions? fuel tank vented so it won't vacuum lock?
Old Jul 13, 2012 | 11:26 PM
The carb is fine. I took it off of my other running quad and the plug is getting wet. Its got to be a valve or ring issue, Like I said. I removed the lower valve inspection cover and oil just poured out. Im not sure if that is normal
Old Jul 14, 2012 | 04:18 PM
jagump07's Avatar
id pull the head and see if the top of your piston has oil on it. could be that on of your valve guides is worn and letting oil pass threw it
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Bratman2
Jul 25, 2015 07:16 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
