Kazuma Dingo 150 fluids???
Old Aug 9, 2012 | 10:14 PM
kazumarider's Avatar
Default Kazuma Dingo 150 fluids???
I have a Kazuma Dingo 150.
What kind of brake fluid?
What kind of oil does it take and how much does it hold so I can do an oil change?
Thanks!
Old Aug 11, 2012 | 01:19 AM
cesar110's Avatar
My guess is DOT 4 for brake, 10-30 *motorcycle* or *ATV* oil (synthetic is better but regular will work fine.). If it runs hot go a little thicker like 10-40 or 15-40. I'm not sure about how much it holds, but you can put a quart in then use the dipstick for checking. You want in the middle in between those 2 lines, if it's over the line or under you will have to drain some or add some
Old Aug 18, 2012 | 12:24 AM
Thanks! Anyone else have a take on it?
Old Aug 18, 2012 | 08:23 AM
Jaster94's Avatar
make sure if you drain some oil, you use the drain plug. there's a possibility that the other plug on the bottom of your engine is the cam tensioner spring and if you remove that, you'll give yourself a few problems.
Old Aug 18, 2012 | 10:42 AM
Spdecat's Avatar
What's the time line on how often the oil needs changed on those machines ? My grizzly they call for oil every 1600 miles and filter every 3200 miles . You should be able to run Amsoil 0w40 .
Old Nov 9, 2012 | 01:49 PM
What kind of filter do these take and where would I find one? and you think a 0 weight would work?
Old Nov 9, 2012 | 02:17 PM
FINALLY somehow found a manual!!!!!!!!!!! So pumped right now!
Dingo 150/250
http://www.highrpmracer.net/download...ers_Manual.pdf
Old Feb 10, 2014 | 05:59 PM
benno's Avatar
Smile Please update link.
Dingo 150/250
I recently purchased two Kazuma Dingo 150's and they both run great. But, I really want to modify them. The link to download the manual is not working can you repost? It keeps asking for a username & password. Any help would be great. Thanks...
Old Mar 3, 2014 | 05:07 PM
Kazuma parts's Avatar
I bought out Kazuma Pacific,the manufacturers parts stock in the USA.Let me know if you need any parts.
Old Mar 4, 2014 | 11:12 AM
benno's Avatar
Default Kazuma Parts
I appreciate the contact, however, they are running pretty well right now. Although I wouldn't mind getting some new tires. It just goes down to the cost of them.
Alex G.
Sep 11, 2017 11:38 PM
hueby
Nov 6, 2015 11:34 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
