How to change oil
Old Aug 19, 2012 | 12:10 PM
Gizza22196's Avatar
Default How to change oil
The oil on my quad needs changing around about now, what steps do i have to follow to do this correctly?
Cheers
also the oil that i have is 10W/40, is that ok to use?
Old Aug 19, 2012 | 07:26 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Not sure what your changing the oil on. Different quads have different tricks. Just don't use car oil. You will need ATV oil, thats much more important than weight. Change oil often. It's the life of any quad.
Old Aug 20, 2012 | 03:15 AM
Gizza22196's Avatar
I'm 99% sure it's a yamoto, what oil would you reccomend?
Old Aug 20, 2012 | 07:08 AM
scootergptx's Avatar
Supersock
Hired Gun!
It depends on what type of transmission you have. If it is a wet clutch system, you would want to use oil with no friction modifiers. A cheap and good alternative is Shell Rotella oil. You can get that at walmart. If it's a cvt transmission, you can use the 10w/40, if that is the weight that is recommended.
Old Aug 20, 2012 | 03:33 PM
essadis420's Avatar
hi I just did a oil change on my gio for my first time. I drained it filled it up and it all looked good. Now when i started it all the oil in the peep hole goes away and it looks like there's no oil but when I kill the engine it comes back and fills right up.
Is this normal or did i just not put enough oil in?
the dipstick does say its full
Old Aug 20, 2012 | 03:36 PM
Gizza22196's Avatar
I'm guessing that's normal as its being used around the system so there is less oil in the sump
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
