kazuma sputters
Old Sep 13, 2012 | 10:43 PM
rawlings's Avatar
Default kazuma sputters
hi hope someone can help i have a 110 quad can start up and idles as soon as i rev it up it starts to sputter checked volts to battery getting only 11.7 max but getting erratic readings think it could be stator or cdi
Old Sep 14, 2012 | 07:33 AM
Jaster94's Avatar
does it bog down when you give it throttle and tries to die? at what point in the throttle position does it start this activity? 1/4, 1/2? right now, if it is bogging down when gunned, i believe we are going to need you to pull the carb apart, pull the main jet and physically clean it. as far as voltage goes, are you pulling the tests on the stator wires or at the battery terminals? i'm sure you've checked the terminal connections for proper tightness and they're clean?
Old Sep 14, 2012 | 08:02 AM
Jaster94's Avatar
now in this video, your carb may not be identical to it, BUT the principal is the same.
Old Sep 14, 2012 | 09:42 PM
rawlings's Avatar
tnks for helping at first i thought it was the carb replaced carb with new one did same thing im thinking it could be the stator cause seems im getting a weak spark took off stator tried to clean it now im getting a very weak spark and it wont start up no more and it would start bogging down as soon as i would give it gas
Old Sep 15, 2012 | 06:11 AM
Jaster94's Avatar
ok, let's get you to try a cheaper remedy. try a new NGK spark plug, autozone/O'reillys should be able to cross reference whatever plug you have now. just the other day, we helped a guy with a no spark issue, turned out it was his spark plug that went bad. he replaced it and BAM, the quad fired up and ran. of course that made him happy after spending a couple of bucks on it. it's worth a try.
then clean the carb and jets. i know you said you replaced the carb, BUT, if you ain't running a fuel filter or if you have solids/debris in the tank/fuel lines, then you'll only suck them up into the carb/jets and repeat your bogging problems. i feel that this issue is a fuel delivery issue. if after we discount the delivery issue and it's still doing it, we'll start with the electrical side, BUT based on what i'm hearing, it's got to be a fuel issue. doing the carb will take about twenty minutes of your time.
Old Oct 24, 2012 | 12:14 PM
archinut's Avatar
I agree this sound like a fuel issue. You say you replaced the carb, but have you adjusted the air/fuel mix screw? You might also check your air filter. Something is off in your air fuel ratio. This will cause hesitation and sputtering that will kill the motor.
Old Oct 25, 2012 | 06:16 AM
Jaster94's Avatar
if it still sputters after you've done all of this, spray ether around the intake boot as it idles, that'll tell you if it's got a vacuum leak too!
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
