repair manual for meerkat kazuma 50cc
help me understand that. what does it do when you start it? will it idle or do you have to gun the throttle to keep it running? will it idle when in gear? i'm trying to understand the part when you said "runs till you shift to neutral". that's got me puzzled. please explain more in detail.
It will start and idle fine. But when you put it in gear it will die. I can keep it running by playing with the throttle but it's tough. And if you pick up the back end 6 inches or so it will die. Or if you push down on the back with a little force it wants to die as well.
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
