Fed up someone please help
Old Sep 27, 2012 | 04:26 PM
Duke1982's Avatar
Default Fed up someone please help
Ok heres the deal.. 07 baja 90cc atv
Replaced carb changed oil. Started ran fine shut it off went to restart lost compression.. So im thinkin rings,piston,rod something like that..
So i start to unbolt the exhoust remove the the bolts on one side cuz there is none on the other lose but will not come off.
Removed the bolts to the clutch cover (the big one) to see if the head was bolt thru there no bolts... Some one please tell me how to take it off b4 i cuz more damage.. Thank u..
Old Sep 29, 2012 | 11:12 PM
RonV's Avatar
Did you try adjusting the valves?
