Top end kit for Adly 90cc 2 stroke and ID help
Old Nov 19, 2012 | 03:47 PM
Wloch248's Avatar
Default Top end kit for Adly 90cc 2 stroke and ID help
I just was given a 2001 Adly ATV 90 by a friend. It need a new top end. Starts right up, idles fine, give it gas and accelerates a little then FLAT! Sputters, chokes, no power, etc. It is a 2 stroke, has never been rebuilt. Was just gone over by a mechanic before it was given to me.
After researching quite a bit online I am a little stumped. I know that it is an Adly/Herchee ATV. It has the body work of an Adly 90Z2 which apparently is the 4 stroke version. This is def a 2 stroke with the CVT clutch trans. I can post pictures later. Anyone know if they badged any of these Adlys with the Z-2 stickers/body work but with a 2 stroke motor?
I have found adlyparts.com. I am pretty sure that I can buy the cyl, piston, rings, gaskets from them. I have also found a complete top end rebuild for a 2002-2004 Arctic Cat Y-12 which through research I found out was made by Adly. The 2 sellers on Ebay don't know if the kit will fit mine. Anyone know if all of the Adly 90cc 2 stroke motors were the same?
Thanks for any help!
exmotocrosser
Sep 13, 2019 06:12 AM
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
WilliamBos
Sep 22, 2015 04:07 PM
