carb rebuild kit
Old Dec 20, 2012 | 07:52 AM
bubba143826's Avatar
Default carb rebuild kit
i just rebuilt my carb on my baja 150 and now it wont start at all before it would run but i thought it was runnin too lean
Old Dec 20, 2012 | 11:25 AM
luke95gxe's Avatar
did you check to see if the float needle is stuck shut? try some ether in the air filter see if it starts up for a minute if it does then its down to the carb. You say rebuild did it come with a new pilot and main jets? the pilot jets seem to be a issue on theses quads i have serviced a few and the pilot jet is clogged. And trust me it doesnt take much to clog it
Old Dec 20, 2012 | 02:10 PM
ghcoe's Avatar
I overhauled my carb last year and had the same problem. Turned out I installed the float upside down. It will go together, but when you install the bowl it will push the float up and shut the fuel off. Took me a bit to figure that one out....
Old Feb 15, 2013 | 02:03 PM
that wasnt it i cleaned it again and now it idles fine but after pressing a 1/4 of the throttle down it boggs down and will kill if i keep on the gas but if i let go it ll idle fine
Old Feb 16, 2013 | 03:29 PM
recently i rebuilt the carb and it came witth a different needle when i first put it in it was the oppisite it would idle fine but if i gave it a little gas it would kill and if i pegged it it would run read the sticky and figured out it was running lean by covering the air intake and it ran better so i took the needle out and put some washers on it to raise the needle up now it only runs if i give a little gas too much gas floods it out please help could it be the needles too high?
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
kelleycully
Sep 15, 2016 02:57 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
yambam13
Jul 4, 2015 01:49 PM
