GY6 150 CC hard to start and boging down
Old Dec 30, 2012 | 09:45 PM
markham55's Avatar
Default GY6 150 CC hard to start and boging down
Hello Ya'll
I am hoping one of you fine folks can shine some light on this issue for me. I am working on my neighbors Chinese Wildfire 150cc atv that he bought for his kids.
It was in bad shape when I started. I have replaced the carb, spark plug, coil , ignition switch, and the starter/kill switch on the handlebar. I can get it running after a few attempts. It will run for a bit then quit. If it give it any gas it dies. After it warms up it runs a little better but it will bog down when I give it any throttle. I dont believe it is a vacume leak but at this point I am looking for any ideas.
Thanks In Advance
Have a Quality Day!
Old Dec 31, 2012 | 11:39 PM
mudmike's Avatar
Did you adjust the carb after installing it?
If no there is a sticky 'how to adjust carb' thread at the top of the general chinese forum.
Old Jan 1, 2013 | 06:45 PM
Jaster94's Avatar
double check compression. may need a valve adjustment. DEFINITELY clean the carb/jets. bogging down is a sign of dirty jets/starving for fuel. change the fuel filter also.
Old Jan 2, 2013 | 08:33 AM
markham55's Avatar
Default Bogging Issue
Thanks Mudmike.
I did adjust the valves and that made a world of difference. The carb is new bit I will take it apart and clean it out as well as replace the fuel filter.
I will let you know!
Thanks Man!
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
