Chinese atv 110 no spark
Old Feb 11, 2013 | 09:13 AM
bc0508's Avatar
Default Chinese atv 110 no spark
I have no spark i did the follow test in the forums and at a loss now on what to try.
Method 1) Unplug the CDI and remove the kill switch pin in the CDI connector on the wiring harness. The pin is held in with a spring tab on the pin itself. You'll have to probe into the connector and push this tab in order to extract the pin. Plug the CDI back in (kill switch wire dangling) and see if you have spark. no spark
Method 2) Unplug the CDI. Turn on the ignition switch and set all kill switches to the run position. Use a meter to measure resistance in of the kill switch pin in the wiring harness connector to engine/frame ground. If the resistance is infinite on the 200K ohm scale then your kill switches/kill switch wiring are OK. If you measure zero ohms then you have a kill switch/wiring issue. Working as it should
The other inputs your CDI needs to make spark are AC Ignition Power, and the Trigger signal. Do the following:
1) Unplug the CDI. In the wiring connector measure the resistance of the AC Ignition Power pin to the Ground pin. You should see 400 ohms or so. What do you measure?360 ohms
2) Measure the resistance of the Timing/trigger pin to the ground pin. You should measure 150 ohms or so. What do you measure? 129 ohms
3) Leave the CDI unplugged. Set your meter to measure AC volts on the 100 volt scale. Measure the voltage on the AC Ignition Power pin to the ground pin while cranking the engine. You should see 40 to 80 volts AC while the engine is cranking. What do you measure? 41 volts
4) Set your meter to measure AC volts on the lowest scale you have. Ideally this would be 2 volts but many meters don't go down this low. In that case use the lowest scale you have. Measure the voltage on the Timing Trigger pin to the Ground pin while cranking the engine. You should 0.2 t0 0.4 volts AC. What do you measure? 1.2 volts
Now for measuring the output side of the CDI:
A) Leave the CDI unplugged. In the CDI wiring connector measure the resistance of the Ignition Coil pin to the ground pin. You should measure less than 1 ohm (but not zero ohms). What do you measure? .7 ohms
B) Plug the CDI back in. Set your meter to measure AC volts on the 20 volt scale. Set all kill switches to the run position. Crank the engine while measuring the voltage on the Igntition Coil pin to ground. Poke through the insulation of the wire if you can't probe the connector. .03 volts
I tired a cdi and coil off a 50cc but I am not 100% sure those parts are good. I never heard the 50 run.
Old Feb 11, 2013 | 09:57 PM
alawoodchuck's Avatar
I had no spark so I had my Grandaughter hold in the tether kill switch and I then had spark. I Wedged a piece of paper so the switch would be pushed in more and have had no more problem.
Old Feb 11, 2013 | 10:01 PM
bc0508's Avatar
I tested the kill switch. It appears it is working correctly on the kill side.
Old Feb 13, 2013 | 03:06 AM
~Ray~'s Avatar
Try replacing the Stator
Old Feb 16, 2013 | 10:48 PM
armagh's Avatar
That doesn't even make sense..
It seems it is just a switch problem.
If it was me I would just by pass the tether switch completely and ride the bike.
If you need the switch for a little kid or something then replace it.
Old Feb 17, 2013 | 02:41 AM
~Ray~'s Avatar
Sorry his last two posts weren't showing up on my side when I posted this, leave it alone.
Old Feb 17, 2013 | 05:51 PM
bc0508's Avatar
It was the stator ran for 5 mins then blew the headgasket.
Old Feb 17, 2013 | 06:07 PM
armagh's Avatar
So now we know..
Tomtom86
Aug 7, 2024 07:40 PM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Waddell4436
Jul 20, 2015 09:46 AM
Unzzy66
Jul 11, 2015 10:01 PM
