honda ct70 110 cc
Old Mar 4, 2013 | 09:16 PM
frankiboys1985's Avatar
Default honda ct70 110 cc
hello i would like to connect my news engine 110 cc on my honda ct 70
how i plug the selenoide ???
the kill switch i connect on cdi to the button on /off on frame ???
i have a cdi box , coil , regulator , wiring
sorry for my english im french
Old Mar 5, 2013 | 09:37 AM
armagh's Avatar
I have 2 of the bikes.
Let me tell you You need to turn that carburetor around. The front wheel will pack so much dirt in it and sling many rocks at it, that it will not run long.
The CT 70 did not have an electric starter the engine you have does. This will be the hardest part I think. The solenoid is basically a heavy duty switch that is activated by a lighter duty switch.
My CT 70s have a small 6 volt battery and I think your starter will be a 12 volt. Also because the starter may be a 12 volt the stator will also be 12 volts. *Again I don't know for sure about the starter's voltageSpam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word
There is a man here, Lynn Richards, that knows all about electrical and electronics. Later maybe he will see this post and tell you what you need to do.
Good Luck
Old Mar 5, 2013 | 09:39 AM
armagh's Avatar
I don't know why my post has all of that "s p a m word " stuff in it. I didn't put it in there.
Old Mar 5, 2013 | 10:26 AM
mudmike's Avatar
Ok if I understand what your asking
I'm reading 'How do I make the solenoid work?'
The solenoid has 2 large posts with nuts on top. Hook one to the + side of the battery and one to the large wire on the starter. It will have either one or two small wires coming out the side one goes from solenoid to one side of start button the other side of start button connects to +. If the solenoid has 2 wires the second wire goes to ground (believe in europe they say earth).
Again I'm reading 'How do I make this work?'.
I'm assuming you know which wire this is on the cdi. Simply run it to a switch connect the other side of the switch to ground. When the switch is closed the bike will lose spark.
i
Old Mar 5, 2013 | 09:20 PM
tanks for fast repond
the picure its true for the kill switch ??
Old Mar 5, 2013 | 09:21 PM
Old Mar 6, 2013 | 07:00 PM
mudmike's Avatar
yup black/white to switch. Then switch to ground. When you close the circut (make connection) the bike should lose spark and die.
Old Mar 24, 2013 | 07:56 AM
what a do with the black/red exciter coil in stator on cdi box ???
my motor the wire is
blue and white -------------I connect the same color on cdi
black---------------------I connect to frame
yellow
yellow
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
