help on a baja 90 atv
Old Mar 30, 2013 | 01:23 PM
donutjohn's Avatar
Default help on a baja 90 atv
I need help from someone please. Trying to get a Baja 90 running for my son. With a new battery i get no power to anything. No starter, no headlights, etc. So I thought it might be an ignition switch. But also when I started to look closer I noticed a wire hanging from the transmission right above the small sprocket. It's attached to the transmission but the other end looks like it was pulled out of somewhere. I tried to find where it might plug into but I can't seem to find it. Anyone got some helpful hints. Thanks in advance.
Old Mar 30, 2013 | 03:07 PM
mudmike's Avatar
Is the wire slightly larger than most other wires on the quad and green? If so thats your ground wire.
Until I read the part about the wire my thoghts were 'blown fuse'.
Old Mar 30, 2013 | 08:02 PM
donutjohn's Avatar
Yes it is green with a brown stripe. Where would it connect back into
Old Mar 31, 2013 | 02:10 AM
mudmike's Avatar
The brown stripe is kinda unusual (not impossible). If it's the wire i'm thinking it is. It should be a bit thicker than most of the other wires on the quad and it is hooked to a bolt on the transmission/engine. The other end should go to the battery.
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
Jul 30, 2015 09:39 AM
