110 brake problem
Old Mar 30, 2013 | 05:59 PM
ageihl's Avatar
Default 110 brake problem
my sons hand brake lever will pull freely but does nothing, Where should I start. Any help is greatly appreciated!!!!
Old Mar 30, 2013 | 06:43 PM
Jaster94's Avatar
is the reservoir full of DOT 4 brake fluid? does the piston actuate up on the handle bar? can you tell if the brake light is illuminating?
Old Mar 30, 2013 | 08:10 PM
ageihl's Avatar
brake light does light up, I'll check the fluid and piston thank you for the info, these Chinese quads have been a great learning experience, my yamaha is a gas and go not much repair, these little guys on the other hand need more attention it seems. Thank You again!!!
Old Mar 31, 2013 | 02:17 AM
Jaster94's Avatar
yes that is true. all of my off brands have taught me how to work on my name brands!
if it is low or empty, just bleed normally like a car/pick up.
Old Apr 6, 2013 | 11:16 PM
ageihl's Avatar
Good call on the fluid!! Turns out the bolt that connects one of the brake lines had come loose. A quick tighten and fluid fill now she is good to go!!! Thanks for the help!!!
Old Apr 7, 2013 | 06:26 AM
Jaster94's Avatar
glad you got it going! good job! enjoy! sometimes we think big problems and turns out it is a little problem. that's a blessing. but eventually, it'll be big and we'll tackle that like the little problems and kick some butt there! anyways, take care and have fun.
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
