throttle problem
Old Apr 7, 2013 | 08:20 PM
jplumber's Avatar
Default throttle problem
260cc Liquid Cooled Daymak. When throttle is applied, quad boggs out and dies. Idles fine. What could be causing this? HELP!!
Old Apr 7, 2013 | 11:27 PM
mudmike's Avatar
On the surface this sounds like a vacuum leak such as a vacuum line that was pulled loose or a bad gasket between the carb and intake.
Also could be from a dirty carb (plugged jet) or a misadjusted carb.
On rare occasions the valves being outta adjustment could cause this but it is also typically accompanied by the machine being hard to start.
Old Apr 8, 2013 | 06:08 AM
Jaster94's Avatar
i concur. plugged/clogged main jet or vacuum leak at intake boot on flange.
Old Apr 8, 2013 | 06:31 AM
jplumber's Avatar
Default Throttle problem.
Thanks for the quick reply. I'm not a mechanic but am pretty good with wrenches. How do I fix it? Do I take carb apart? Is there a trick? Some guidance would be much appreciated!! Thanks!!
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
