Peace sports 125cc hard shift?
Old Apr 24, 2013 | 06:30 PM
Loki1000rr's Avatar
Default Peace sports 125cc hard shift?
Replaced the clutch, now it won't shift without brute force.
Old Apr 24, 2013 | 08:55 PM
Loki1000rr's Avatar
the clutch spun off the shaft! cannot figure out how, as I re-installed it i dont se any way it could happen again! fingers crossed!!
Old Apr 25, 2013 | 01:39 PM
Loki1000rr's Avatar
Well happened again!!! how the hell is it possible! I know it was secured properly!Im going to lose it, I have to pull the case off again!!!
Old Apr 26, 2013 | 05:18 AM
Jaster94's Avatar
look real closely for tolerances/excessive wear. it's gonna be something simple. just look it over with a fresh mindset. be patient.
Old Apr 26, 2013 | 07:10 AM
Loki1000rr's Avatar
thank you Jaster. It happened instdantly so I pulled the case again. The lock washerl/set washer.. stripped off an let the nut lose!!! An I replaced it with the original one... sounds like it happened again!!!.. im lost .... new shaft? new washer an nut? is there something im missing?
Old Apr 26, 2013 | 08:00 AM
Jaster94's Avatar
can you drill the nut and convert it to a castle nut with a cotter pin/key?
Old Apr 27, 2013 | 09:33 AM
Loki1000rr's Avatar
To be honest I was going to spot weld it as mad as I was!!! Your idea is bettter...
Njrider1230
Jul 29, 2023 05:16 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
chris7420
Jul 30, 2015 02:04 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
