Kazuma 110
Old May 4, 2013 | 04:42 AM
Jimkalfakis's Avatar
Default Kazuma 110
Hey I got a Kazuma 110. What is the little filler cap on the left side of the motor?
Old May 4, 2013 | 10:19 PM
The_Mechanic89's Avatar
90% sure its the timing hole if u remove it you should see the flywheel no oil on the left side o most
Old May 5, 2013 | 04:35 AM
Are you sure? It's a chrome screw cap on the same side as the chain. I thought it might be for chain lube.
Old May 26, 2013 | 07:32 PM
Jaster94's Avatar
chain lube is external that you apply.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
michdagh
Sep 19, 2002 05:32 AM
