Kazuma coyote 110 master cylinder replacement
Old May 13, 2013 | 02:44 PM
eroc1313's Avatar
Default Kazuma coyote 110 master cylinder replacement
I replaced master cylinder which is connected to the brake pedal. I tried to bleed it but the fluid runs out slow and pedal stays mushy. How should I properly bleed one of these brake systems ? It has a bleed on the caliper on rear of machine
Old May 13, 2013 | 04:55 PM
alawoodchuck's Avatar
Did you pump the pedal up and hold it while opening the bleeder valve and then close the valve before releasing the pedal and pump it up again until it's firm with no mush.
Old May 15, 2013 | 06:15 AM
eroc1313's Avatar
yes i did . just like a car. did it many times'
eroc1313's Avatar
its just oozed out slowly.
Old May 15, 2013 | 08:16 AM
seems the valve isn't opening all the way or is plugged. Take it all the way out and inspect and check the fluid flow with out it in the cylinder.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Schneider
Jul 24, 2015 05:05 PM
Sandman2.0
Jul 21, 2015 09:03 AM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
