Daymak 200
Old Jun 25, 2013 | 07:09 AM
ditton's Avatar
Default Daymak 200
Good morning all.
Over the weekend I obtained a free Daymak 200cc ATV from neighbour who had it at his cottage. He wanted rid of it as it hasn't run in over 2 years. He said it was running before last stored..never to be used again...So I thought it would do for my daughter. So, I am familiar with 2t motor bikes....so here goes.
I figure before I get to involved I would start with the following.
-dump old gas
-cleanup carb/jets and filter.
-Dump old oil (anyone know what grade and how much is best)
-check for spark using battery charger(has start position)
After that, see if runs or not.
Anyone have any other things to check or common problems that I should be aware of.
As I don't have a manual and previous owner forgets (duh )...the left lever on bars.....looks like a cluch as cable goes down to engine, which is similar to my bike....other quads I have seen this is where the brake is located. Only brake on this looks to be foot brake. This lever is tight. When moving gear lever it feels like 1 gear down (reverse?), above that neutral, above that it feels like 2 more gears. Is this correct.
Thanks in advance for reading. Hope to get running as daughter is now wanting to get on and go........
Ditton
jplumber
1) Engine problems..
20
May 11, 2013 06:42 AM
craigolio1
May 5, 2013 06:47 AM
Razor344
Sep 11, 2011 04:08 PM
iCAMPTASTIC
Sep 11, 2011 03:59 PM
check
Oct 31, 2007 11:33 AM
