Compression for 70CC Chinese motor
Old Jul 2, 2013 | 10:41 PM
Stapleton1184's Avatar
Also start with the easiest problem first pull the carb give it a good cleaning check air filter fuel filter fuel lines sparkplug all of the easy stuff the timing is pretty easy I tried to read and comprehend the timing but you tubed it and found it was easy I hope you find the issue
Old Jul 16, 2013 | 06:09 PM
harrisonhunter's Avatar
Well finally got around and got 10mm fitting for my tester and compression check on the 70cc.
The best I could get out of it is 62 PSI.
Would this make sense why I can seem to keep this this running?
Old Aug 2, 2013 | 07:50 AM
Where do guys buy your motor parts from? Sounds like I need to replace a piston cylinder and a couple valves.
Old Aug 12, 2013 | 04:07 PM
Thanks for all you advice.
I ended up taking the motor apart and found out that I had a piston with worn down rings.
I bought a new cylinder and piston and rings.
I checked the valves and they are tight with alot of carbon build up on them. I poured some alcohol in the combustion chamber to see if they leaked.
After getting it all back together I still have a bog.
With the float set at 10 degrees above with the carb upside down.
The needle clip in the middle and the air screw turned out 3/4 turn.
It won't even start with the air screw turned out 1 1/2 times.
The plug is BLACK. It is a stock carb (PZ19)
My head is spinning.
Thanks
Jay
Old Sep 7, 2014 | 01:52 AM
  #15
weekendwally's Avatar
Hi Jay,
Sorry to dig up an old thread but I need to know if he solved this. I have the same issue. Identical symptoms on my sons 110cc quad. I have tried a new carb, CDI, Coil, and spark plug. Idles fine, no power, sputters out.
Were you ever able to solve this? Very frustrated, if I can't figure it out soon, I will have to scrap it...
Thanks in advance for the reply.
Old Sep 8, 2014 | 12:03 PM
  #16
I figured it out! I'm a fool!
Really what happened, is I cleaned the air filter and oiled it, just like I have done on every bike I have ever owned. I guess that the air filter oil is too thick. No oil is required on these cheap air filters.
Took the filter off, and it ran like a champ. The filter is now going to be washed and put back on without the oil. I will probably go buy a real foam filter soon.
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Waddell4436
Jul 20, 2015 09:46 AM
Waddell4436
Jul 19, 2015 04:22 PM
ghost civic
Jul 19, 2015 10:13 AM
