Bashan 200S-7 (2008) Spark Plug????
Old Aug 29, 2013 | 10:27 AM
leerx7rsuk's Avatar
Default Bashan 200S-7 (2008) Spark Plug????
CAn anybody tell me what the original spark plug code is for this quad and the NGKR number. I've just put a new one in my Bashan along with new piston and rings. The one i put in is a NGK-R DR8ES. I threw the old one away before getting the number but it was different (idiot LOL). Not sure why its running iffy when warmed up. Thought it was the carb that had oil in it before i did the work.
Cleaned the carb out and reset it (It was on the richest pin setting????) any reason why.
When hot it struggles to drive past 30kmh and hesitates alot even died on me then started again after 5 minutes as if its being starved of fuel. I've checked the fuel lines and fuel is getting there ok just wondered if it was the spark plug i've bought!!
Any help would be appreciated or if anybody has one can the give me what plug code they have as ive looked online and there is a few
regards
Lee
Old Aug 30, 2013 | 03:20 AM
leerx7rsuk's Avatar
c'mon guys...... what spark plug is in your bashan 200s-7 as need to know if i have the correct one
Old Aug 30, 2013 | 10:40 AM
Close as I can find. Maybe some else that owns one can help better..
NGK Spark Plug D8EA 2120 for Bashan BS200GY BS 200 GY 01->: Amazon.co.uk: Car & Motorbike NGK Spark Plug D8EA 2120 for Bashan BS200GY BS 200 GY 01->: Amazon.co.uk: Car & Motorbike
If you have a DR8ES in it now basically the same plug. The R stands for resistor.
Old Aug 30, 2013 | 12:50 PM
leerx7rsuk's Avatar
Hi thanks for the reply at least somebody could try to help. C'Mon guys there must be more of you that has a chinese chocolate quad like mine LOL. Have a look at ya plugs for me. The one i took out was a NGK-R as the new one i put in but different number!!
Old Aug 31, 2013 | 09:46 AM
armagh's Avatar
I am going to ask the question...
How do you know it is a different number IF you don't know the old number? Is that you hope it is the wrong number so you can buy a new one and then that will fix the problem?
When did it develop this problem? Before or after the piston and ring job? Or after you "reset" the carburetor?
Is it getting exceedingly hot or just normal running hot.? How long does it take for it to get this hot?
Old Aug 31, 2013 | 01:02 PM
leerx7rsuk's Avatar
I know it was different as when i took it out i half clocked the old number and it was different to the new one. Should have kept the bloody old one but there you go. It only started playing up when the new piston, rings and plug was fitted. When cold it runs mint but after 5/10 min it starts struggling to drive and bogs. Idles fine but when you hold the revs up its very uneven
Old Aug 31, 2013 | 02:02 PM
armagh's Avatar
OK, I am just guessing at this, but my guess is it isn't after it sits and idles for 5/10 minutes, and another guess on my part is that it isn't overly hot or as I put it in my question to you it isn't "exceedingly hot". How am I doing on my guessing??
Try a new NGK D8EA like "Old Polaris Tech said"
That should be the plug for it.
Also another question for you. Why did you buy the plug that you did for it, when you didn't know what went in it??
I sound like a smartass don't I ?? I tried to help you. I asked questions that you didn't/ wouldn't answer. I used proper English instead of slang so there would no mistake on what I was saying, didn't I? I wanted you to understand what I was saying to you. so I could help you.
let me guess again... You don't care..
Anyway that should be the plug for it.
Good Luck
Old Sep 1, 2013 | 09:06 AM
leerx7rsuk's Avatar
Gonna buy a D8EA tomorrow and take it from there...i hope its just that
Old Sep 2, 2013 | 01:18 PM
leerx7rsuk's Avatar
Thanks to ''Old Polaris'' the D8EA worked a treat although not an NGK-R a normal NGK but who cars its running good again although a little spluttery when you first excelerate but cruizes fine so presume its **** in the filter or air filter when the carb got caked in oil so gonna get a new aire and fuel filter next week but happy days..Thanks for all the help!!!!
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
D-Hagz
Jul 4, 2015 02:19 AM
