Sunl 110cc Quad not charging?
Old Oct 5, 2013 | 01:40 PM
tbutler01's Avatar
Default Sunl 110cc Quad not charging?
I have a Sunl 110cc 4 wheeler that is not charging the battery. I measured the AC voltage from the stator on the white and yellow wires with the regulator unplugged. With the engine running, I was only getting about 3 volts AC. So I figured the charging part of the stator was bad. I installed a new stator and I still only get 3 volts AC on the yellow and white wires going to the rectifier! The engine cranks up and runs fine......just no charging voltage out of the stator! Am I doing something wrong? Thanks for your help!
Old Oct 6, 2013 | 10:33 AM
tbutler01's Avatar
Any ideas, experts? This is getting strange!
Thanks!
Old Oct 6, 2013 | 10:36 AM
Zrock's Avatar
Super Quad Patrol
i would start by finding all your grounds and cleaning them all
Old Oct 18, 2013 | 10:09 PM
tbutler01's Avatar
Update: Received another new stator and installed it. Same results......3 vt AC at idol and 9 vt ac at hi revs! Again,,,,this is with the regulator unplugged and meter on the white and yellow wires from the stator! Checked the wiring and grounds...all good! WTF?? Also made sure the flywheel and stator was clean! What can cause a stator (two now) to put out half of the required voltage?
Thanks!
Old Oct 19, 2013 | 09:30 AM
Zrock's Avatar
Super Quad Patrol
What voltage are you getting at the battery with everything plugged in and running? U sure you don't have a bad meter or low batteries in your meter
Old Oct 19, 2013 | 10:39 AM
tbutler01's Avatar
Meter is ok. I'm looking directly at the charging wires coming out of the stator with the regulator unplugged! White to yellow shows 9vt AC max at hi RPMs! Anyone know how to tell if the flywheel may be bad? The voltages to the pickup coil and the CDI are good! HELP! LOL
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
musselmark
Jul 17, 2015 02:40 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
