Will CDI damage engine
Old Oct 18, 2013 | 03:12 PM
wsy3benz's Avatar
Default Will CDI damage engine
Hello all,
New to ATVing, picked up a no name Chinese 200cc quad and getting it in shape hopefully to do some trail riding.
I was getting intermittent no spark so I ordered a new 6 pin CDI, when the CDI got here I plugged it in and it seems to work. The problem is if I crank and it doesnt start the engine seems to do a backlash..sounds terrible. A few has said that it may be a high performance CDI with advanced timing.
The problem is I ordered a cheapie CDI for 5 dollars w shipping. Could it be that the CDI I have has a different timing profile?
Biggest concern is will this CDI harm the motor? It works good except for the backlash noise..I would keep as spare if no harm to motor.
Thanks in advanced.
Old Oct 21, 2013 | 11:12 AM
armagh's Avatar
Try a higher octane gasoline. See what that does.
Old Oct 21, 2013 | 05:44 PM
brumbear's Avatar
you could try adjusting the valves or static timing if possible.
Old Oct 21, 2013 | 08:31 PM
wsy3benz's Avatar
Brum and armagh ..thanks for the suggestion. This is only happening on the New CDI I ordered.
The Old CDI starts fine and does not make that backlash noise. Only the new one I received. I will probably order another one as they are cheap.
Thanks for the reponse.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Reactant
Jul 27, 2015 07:45 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
