E-ton Yukon yxl 150 no start
Old Dec 5, 2013 | 06:06 PM
YOUNGONE's Avatar
Default E-ton Yukon yxl 150 no start
Ran good and suddenly quit will start sometimes-- it's not carb as I have no spark!! I need some info on how to test cdi-- stator-- and so on.. Any help would greatly be appreciated !! Thanks in advance.
Old Dec 26, 2013 | 12:23 PM
Jaster94's Avatar
1st thing 1st, change the spark plug, then you'll need to check the trigger and stator magnet. but let's get the easy stuff out of the way first. put in an NGK spark plug and see what happens.
Old Jan 2, 2014 | 05:17 PM
YOUNGONE's Avatar
. I installed a new plug" champion" and it still won't spark.. Should I get an ngk even though this is the second new plug I've installed??
Old Jan 3, 2014 | 05:30 PM
Jaster94's Avatar
no, tell ya what, look at the kill wire coming off of the CDI and then check out the red slider kill switch on the left handlebar.
Old Jan 3, 2014 | 08:09 PM
YOUNGONE's Avatar
Ok I believe this quad has two cdi boxes..?? Can you show me a diagram of these and which is the ground?? I unhooked the plug for the handle bar switch I believe is the correct wires for switch and no change.. Thanks for any help in advance!!
Old Jan 4, 2014 | 08:57 AM
Jaster94's Avatar
let me go out there to mine and look it over.
MikeyBoyesq
Nov 27, 2020 02:44 PM
1000gade
May 27, 2015 12:37 PM
weedy
May 6, 2007 05:24 PM
hopper
Sep 6, 2000 01:00 PM
jaybeecon55
Apr 4, 2000 01:50 PM
