Oil in the gas- now wont start
Old May 12, 2014 | 01:32 PM
wannabe32's Avatar
Default No spark!
Appears that there is no spark on the new plug. Guess I should have checked earlier. I've charged the battery and seem to be getting power to the starter and I smell gas. What parts of the ignition should I start with? Guess the oil in the gas was more coincidence than cause.
Old May 27, 2014 | 10:32 AM
wannabe32's Avatar
I'm going to wrap this up. New ignition coil and new fuses in and starts right up. Expect I just needed a fuse which reminds one to start with the simplest before moving to the more complex. Other lessons for this novice: Wiring diagram that came with vehicle is wrong. Shop manual directions even more wrong- don't test the spark plug cap and don't bother testing the secondary coil on the ignition coil. I spent too much time on this but at least learned some good lessons and didn't throw too much money after a fix. Thanks to everyone who helped along the way.
Old May 27, 2014 | 10:35 AM
wannabe32's Avatar
Originally Posted by Ace1996
Try checking to make sure that you are getting spark to the plug. It sounds like it's not firing.
You win, sir!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
