Jackel 50 atv please help
Old Dec 21, 2013 | 03:17 PM
bzboardco's Avatar
Default Jackel 50 atv please help
I bought a Jackel 50 atv for my sons xmas the fourwheeler ran great. Pulled plastics and painted them and installed a new few fuel line. put plastics back on and fuel line added gas and no start. I can start with starting fluid but of course quickly dies. I take fuel line off at carb and getting fuel thru line but when i loosen drain on bottom of carb no fuel. Can you please help me. I got 4 days to get it running. thank you!
Old Dec 21, 2013 | 05:07 PM
brumbear's Avatar
The float valve gotta be stuck closed try tapping the carb on the side see if that helps otherwise gotta open it up
Old Dec 21, 2013 | 07:55 PM
bzboardco's Avatar
Thanks! i was wondering that but ran out of time today to work on it so wanted to see what others thought
Old Dec 22, 2013 | 10:04 AM
Zrock's Avatar
Super Quad Patrol
another thing you can try is take a length of fuel line and hook it up to the carb. fill it will fuel and blow the fuel into the carb. i had similar issue and i think it was just a air lock in the carb as once i got the bowl full never had a issue again. I know the float was not stuck then i did this as well
ugswife
May 8, 2012 07:11 AM
Rookie123
Dec 22, 2005 10:51 AM
poe900rr
Jul 28, 2005 04:41 PM
diggler
Apr 8, 2005 07:59 PM
