Jackel 50CC
Old Dec 19, 2005 | 02:00 PM
Rookie123's Avatar
Default Jackel 50CC
I ordered what i thought was a 50CC KAzuma Meercat and today when it arrived it was a 50CC Jackel.
I called the dealer, Kazuma USA, and they said they were out of the meercat's, so he gave me a "free" upgrade. He said they are much better than the Kazuma's and use better parts etc; The finish looks good but I don't know much about ATV's.
Have any of you heard of Jackel?
What would you do in my situation?
Thanks,
Chris Halter
Old Dec 19, 2005 | 02:03 PM
maggiesboy's Avatar
"One Wheel Short"
Default Jackel 50CC
Jackel was advertised really hard and heavy here on the forums a while back. I can't recall ever seeing much posted about them, good, nor bad.
Old Dec 19, 2005 | 07:58 PM
2manytoys's Avatar
Default Jackel 50CC
rookie123,
Jackel is a good atv because they actually took the time to go through the atv and replace all the cheap bolts with grade 8, better carb, airfilter and go through everything to make sure they are solid. It is a Kazuma with more attention to detail. If that is what you got then you made out good. Keep what you got.
Old Dec 19, 2005 | 08:07 PM
maggiesboy's Avatar
"One Wheel Short"
Default Jackel 50CC
Thanks for that info 2many. I did not know that was the same beast, with better fixin's. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 19, 2005 | 08:17 PM
2manytoys's Avatar
Default Jackel 50CC
Thats exactly what they are.
Old Dec 19, 2005 | 08:56 PM
Rookie123's Avatar
Default Jackel 50CC
OK Great! I was alittle worried because they told me they were sending a Kazuma and I got a Jackel. I thought they were pulling a bit of bait and switch.
Thank you for your help! The dealer is Kazuma USA in Texas, which I have found out also owns Jackel.com
Best Regards,
Chris Halter
Old Dec 21, 2005 | 03:18 AM
Jimi's Avatar
Default Jackel 50CC
I know that Jackel screams that they use Japeneese seals,bearings,carb ect.I have owned a 50cc Kazuma for years,my two boys have hammered on it,along with there friend's.The one my kid's own has been totally trouble free.My question is...Has anyone had a Jackel appart and has seen the upgraded seals and gaskets? And is it necessary?
Old Dec 21, 2005 | 08:49 PM
Rookie123's Avatar
Default Jackel 50CC
Update:
I went out this morning and got it started and it ran great. I discovered the problem was the fuel line was pinched between the tank and the carb, so the carb wasn't getting any fuel. It's almost ready for my son for Christams!
The last thing I have to do is change the oil. It is really tuff to get to the drain bolt. Does anyone know any tricks? The frame partially blocks the bolt, making it difficult to get to.
Old Dec 22, 2005 | 10:51 AM
spliffy's Avatar
Default Jackel 50CC
The easiest way to change the oil on them little 50's, is to warm up the engine, turn off gas, take out oil fill plug & tip the machine on its side & let it drain right out the same hole you fill it with, have been doing that for years & it makes a 5 minute oil change & have had zero problems with the engine.
Ramman1
Aug 11, 2022 01:53 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
firsttimerider
Technical and How-To Articles
Aug 27, 2015 02:09 PM
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
