ATA-125D electric works intermittently
Old Dec 29, 2013 | 08:19 PM
Chevyfish's Avatar
Default ATA-125D electric works intermittently
Battery is good, fuses good. Turn key on no lights nothing. Disconnected battery, reconnected then I have lights, starter etc... When I have nothing, it will start via pushing and jump. Any help would be appreciated.
Old Jan 2, 2014 | 06:25 PM
wsy3benz's Avatar
CF , if it is a Chinese quad I would check the wiring for loose, soldered and connections with poor ground. Follow the wiring from the battery. Check that ground wire and make sure it has good ground.
Old Jan 2, 2014 | 06:40 PM
brumbear's Avatar
make sure the cheesey fuse holders are not loose
Old Jan 3, 2014 | 10:27 AM
Zrock's Avatar
Super Quad Patrol
check all the wiring. I just did one of my machines and i was surprised it ran the solder joints were so bad and falling apart that i cut them all out and redid them and shrink tube everything
Old Feb 13, 2014 | 08:26 PM
Reaper9789's Avatar
wiggle the key, my ignition switch has messed up on me and the atv isnt even 2 months old.
skinnyr6
Aug 25, 2023 02:18 AM
hugemoth
Jul 20, 2020 03:28 AM
ranvette
Jul 4, 2015 06:13 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
