Will this light work?
Old Jan 29, 2014 | 06:20 PM
NRXTM's Avatar
Default Will this light work?
will this light work on my atv? I was going to wire straight off the battery with an inline fuse and switch or just remove stock headlight and connect to existing headlight wires. Anything wrong with doing any of the two? also will there even be enough energy to power the light? pics of atv and link to light below
http://www.ebay.com/itm/321302767638?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jan 29, 2014 | 06:39 PM
Bkumler's Avatar
That LED light uses a lot less electricity then the stock head light. Granted my ATV is a 500cc. I mounted a 36 watt LED light bar on mine and run an electric winch for my snow plow and I have no problems. But I also disconnected my two stock headlights.
Old Jan 30, 2014 | 09:47 AM
Zrock's Avatar
Super Quad Patrol
i wired up my 12" led bar to my headlight switch and took out the stock lights since they were unless.. you will have no problem. Check under the front for some extra wires. Alot of the times they will have extra connections for add on lights
Old Jan 30, 2014 | 04:18 PM
NRXTM's Avatar
thank you
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
bikedad3
Jul 2, 2015 02:15 AM
