Reversed Jumper Cables - Dead?
Old Mar 31, 2014 | 04:15 PM
Forneyatvpapa's Avatar
Question Reversed Jumper Cables - Dead?
TAOTAO ATA-110H is dead because i accidently reversed jumper cables directly onto the positive & ground large-gauge ring-terminal wires.
There is no clicking sound, nothing seems to be alive. I replaced the stator, solenoid, and the cdi box. The kill switch AND the lights AND the reverse have all been disconnected from the very first time we purchased it used.
Prior to reversing the j-cables...we were always cranking it up with j-cables because both new and old batteries did not provide enough amps to get it turn over.
Old Apr 1, 2014 | 08:51 AM
Zrock's Avatar
Super Quad Patrol
Did you check for the obvious first? Fuse or burnt wire? If you had a new battery in their and it still would not turn over and you had to jump it you had a bad wire some ware.
Old Apr 1, 2014 | 06:50 PM
brumbear's Avatar
you blew the fuse under the tail section in the clear holder
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
