Coolster ATV 4 stroke won't fire
Old Apr 20, 2014 | 09:41 PM
The outside guy's Avatar
Default Coolster ATV 4 stroke won't fire
Hey guys, I'm new to all this atv stuff and not very mech. Inclined. When I push the start button nothing happens. Battery is charged and I also had charger connected to keep amps Up. No clicks nothing. If I cross both sides of starter solenoid it will crank over easy but won't pop off. Removed spark plug shot a little starting fluid replaced spark plug. Had to cross solenoid again and popped off and ran for 2 seconds then died. Have fuel and fuel comes through fuel filter up to the fuel pump. So couple things here. First do you think I need a new solenoid, a starter or is there some electrical short somewhere. Second, fuel? Do I need a fuel pump also. Or is fuel pump associated with possible electrical issue along with solenoid. Ran last summer then all the sudden stopped. Unit hasn't run in 1 year. Look forward to hearing your advice
Old Apr 21, 2014 | 10:17 AM
alawoodchuck's Avatar
Check safety switches. Tether, brakes, on/off switch.
Old Apr 21, 2014 | 06:09 PM
Only safety switch I see is the on/off on handlebars, no rear tether, not sure what/where to look for anymore
Old Apr 21, 2014 | 08:13 PM
One of the brakes probably has to be depressed before it will crank. This is a safety switch.
Old Apr 21, 2014 | 09:08 PM
Yeah I have done that. Pull the brake or push on foot either one but still doesn't work unless I cross over terminals on solenoid
Old Apr 22, 2014 | 09:31 PM
Still looking for some help if anyone has any suggestions I would appreciate it thanks
ultangler
Nov 30, 2024 01:35 AM
flyin-lowe
Dec 1, 2017 03:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Elkaholic
Sep 6, 2015 02:44 PM
