no spark...help
Old May 20, 2014 | 03:40 PM
atc guy's Avatar
yes in neutral light comes on when you put it in neutral .and you're talking about the middle.wire of the hot side of the CDI
Old May 20, 2014 | 07:10 PM
whygostockcom's Avatar
Banned
It should be the only wire in the middle of the CDI harness at the CDI. If not, we would need to see a picture of your CDI.
Old May 20, 2014 | 08:13 PM
atc guy's Avatar
the CDI has 5 pins .three hot on the top and two grounds on the bottom
atc guy's Avatar
it is a four and two configuration with the four only having three wires
