pressure at spark plug
Old Jun 7, 2014 | 11:39 AM
bamax100's Avatar
Default pressure at spark plug
got a Fuxin 110cc quad. Engine was slightly seized, got it unstuck very easy and started to work on it to see if it would start up. I can get it to turn over,sounds really good, plenty of compression it seems but it will not fire. New jets, cleaned carb, used good parts from a running 110 but it just will not fire up. Took the spark plug out and it had pressure on it, more I loosened it, it hissed air.
Not sure I have ever had 1 do this so wondering what it might be a symptom of
Old Jun 7, 2014 | 06:43 PM
If it was "slightly" seized it may "slightly" try to start. Best to do a compression check to see where you stand.
Old Jun 7, 2014 | 10:07 PM
Reaper9789's Avatar
Push start it if you can.. my little 125 doesn't like to start in the cold, but if I push it, it will start. It's an auto btw. You can still push start it.
Old Jun 8, 2014 | 09:45 AM
Zrock's Avatar
Super Quad Patrol
do you have spark? try a squirt bottle wit fuel and spray direct in carb. But like stated above check your compression first
Old Jun 8, 2014 | 06:36 PM
bamax100's Avatar
yes has spark. and ive sprayed it with gas.
Old Jun 8, 2014 | 06:58 PM
Do a compression test on it. Partial seizure could be from the piston/ rings or lower end bearings,etc.If compression shows around 100 psi or less you may just be wasting your time trying to crank it. If this is a 4 stroke Honda/Suzuki clone engine you might want to check valve clearance also if you just got this machine. At least it should have .002-.003 clearance on the intake and exhaust valve clearance.Tight valves can cause problem starting also.
STLyamwar
Jul 25, 2020 04:44 AM
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
