2008 linhai4x4 250 wnt start
Old Jul 4, 2014 | 02:28 PM
daveo2008's Avatar
Default 2008 linhai4x4 250 wnt start
hello im having problems wit my linhai. have had it for 2 years wit no problem. than all of a sudden wouldn't start. nxt would start. and hasn't wanted to start since. just cant seem to figure it out. any help wit this would b appreciated thanks
Old Jul 5, 2014 | 06:51 AM
Jaster94's Avatar
Define no start or won't start. Cranks but won't fire up or doesn't crank (starter turns engine over)?
Old Jul 7, 2014 | 01:36 PM
daveo2008's Avatar
it turns over no prob, but wnt fire up
Old Jul 7, 2014 | 03:44 PM
Jaster94's Avatar
ok, as it cranks, have you checked for spark? i know this may sound silly, but sometimes a new NGK $3 spark plug fixes this before we even have a chance to check out other possible contributing suspects in the ignition system. next, is the spark plug wet with gasoline? is the gasoline making it into the carb and into the jug/cylinder? have you tried cranking it, giving it a small shot of starting fluid in the air filter box and seeing if it tries to start?
Old Aug 4, 2014 | 02:02 PM
daveo2008's Avatar
it has no spark and have tried new spark plugs and tried couple coils but still no spark
Old Aug 5, 2014 | 11:00 AM
Jaster94's Avatar
so, let's test the red slider kill switch. also look behind the keyed ignition and make sure the leads are connected.
Old Aug 5, 2014 | 12:09 PM
daveo2008's Avatar
kill switch started screwin up bout a year ago have it wired together. has power running thru it its workin and lost my keys while ago so had wired up a new key ignition and its workin
Old Aug 5, 2014 | 03:34 PM
Jaster94's Avatar
so do you have power to the coil and then any measurable power out the coil wire? are there cracks in the coil wire or burnt/heated up spots which could be damaged?
Old Aug 5, 2014 | 03:35 PM
Jaster94's Avatar
also check the CDI quick connect as the blades can push back and not make good contact thus killing power to coil.
Old Aug 5, 2014 | 06:11 PM
daveo2008's Avatar
theres power to coil. and no cracks in coil or burnt or heated spots.. buddy of myn used trouble light and cdi has power.we tried a couple diff coils and still had no luck.
Mkp
Mar 28, 2020 03:50 AM
toonces
Jun 30, 2015 11:19 AM
RedRancher
Jun 4, 2015 12:29 PM
Schneider
Jun 4, 2015 11:37 AM
1000gade
May 27, 2015 12:37 PM
