non-start w new part
Old Oct 6, 2014 | 01:10 PM
bamax100's Avatar
Default non-start w new part
Panther 110cc. Would start intermittingly,run for a few seconds and cut off.Now,no start at all. Did the 5 pin thing,getting no spark. I assume I have no key/switch/kill issues?
But,Replaced the cdi,and coil.Still no spark.
Last thing to check is pickup coil? sound about right?
Old Oct 28, 2014 | 09:28 PM
Ace1996's Avatar
The first thing I would check just to eliminate needless spending is to make sure that all your connections are solid. Check to make sure none of your wiring pins are lose. Also, is the engine cranking good or weak? If all that is good, then I would test your pick up coil with an ohm meter before buying one, but it sounds like you are on the right track to me. Also, what does your spark plug look like? Is it new or old? Does it look burnt? It may be gapped incorrectly.
1986Vmax540
Jul 9, 2021 09:53 PM
DFWSRT8
Aug 20, 2015 09:24 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
