Leaking Gasoline between the upper and lower bowel on the CARB - COOLSTER 125
Old Oct 10, 2014 | 02:13 PM
rickbass's Avatar
Default Leaking Gasoline between the upper and lower bowel on the CARB - COOLSTER 125
Hello, just got a brand new coolster 125 and there is gasoline leaking out between the upper and lower bowel on the carb. see arrow on pic. There is to screw to tighten it down, any suggestions?
[IMG][/IMG]
Old Oct 10, 2014 | 05:50 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The gasket is bad.. You need a new carburetor.
Old Oct 11, 2014 | 12:56 AM
Swiftyyy's Avatar
Now, no need for a new carb quite yet.. Just take it apart, clean it, cut the gaskets if you need to get them to fit and then just apply silicone over the gasket and put the crb back tohether. You night also want to use some hot glue gun glue o, the gaps and mixture screw as well as the screw used to enpty the carb bowl. That one likes to leak..
Old Oct 11, 2014 | 06:20 AM
KTM Patrol
Former Chinese POW!
That carb doesnt seem to have screws holding the bowl on?
maybe riveted together?
Old Oct 11, 2014 | 10:09 AM
Zrock's Avatar
Super Quad Patrol
Looking at the pic it looks like the mating surface is warped. So you have 2 options. Take some fine sandpaper and a flat surface and touch both up until they are flat. Or get some automotive silicon and apply a small amount to each surface and put back together. then let sit 24 hours before putting fuel to it to fully cure. Remember a small amount you do not want to get any inside the bowl. I usually just put some on my finger and put a paper thing bead all the way around
Cole Hadden
Jun 15, 2025 09:05 AM
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
