starts but wont run
Old Jul 13, 2015 | 12:50 AM
Bob Maurice's Avatar
Default starts but wont run
I have a gio 110cc and 90cc. both ran great last summer but a little stubborn to start when cold. Now they will only start with quick start but will not keep running. I have taken carb apart and cleaned but still same results. Gas is getting to carburator but spark plug seems dry. Not sure if this would be a valving issue. If anyone can help it would be appreciated. thank you.
Old Jul 13, 2015 | 05:17 PM
If gas is getting to the carb but the plug is dry,sounds like either jets are still stopped up or possible needle and seat stuck not allowing fuel into the bowl. Drain the bowl screw first to see if fuel is getting into the carb. If it is,then I'd recheck the main and pilot jet. Gotta see daylight through them.
Old Jul 14, 2015 | 09:05 AM
Zrock's Avatar
Super Quad Patrol
ya make sure all the jets are clean. When cleaning one of mine i did not realize it actually had holes around the outside. Took a pin to poke the crap out..
You are getting spark right?
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
