Help I'm stuck
Old Dec 30, 2015 | 12:03 PM
Doryan Green's Avatar
Arrow Help I'm stuck...can't keep my eton Yukon 150 cranked when pressing the throttle
I recently purchased a eton Yukon 150. I had the carburetor cleaned and it was running. After riding for a while it lost power. It will still start but it cuts off when I give it gas. Like its getting bogged down or flooded out. If I let it sit for a while it will start run and do the same thing. Could anyone tell me what the problem is and how could I fix it?
Old Dec 31, 2015 | 03:05 AM
Either the carb needs cleaning again or not enough fuel getting through. A blocked tank filter can slow the supply to the carb, as can a blocked tank vent, which causes a vacuum in the tank. Some engines need choke when cold, and will cut out if part choke isn't used until they warm up. However, if the choke sticks open, an engine will run badly once warm.
Old Jan 2, 2016 | 07:59 PM
MPDano's Avatar
Does this model have an electric choke or is it manual. Try and post pics of the carb set up. Does it get hot?
TRXWOLV
Dec 16, 2015 07:39 AM
suz1100
Dec 12, 2015 05:01 AM
crkola
Dec 11, 2015 01:47 PM
jmoore0128
Dec 4, 2015 09:51 AM
Jim MgGinn
Dec 4, 2015 01:01 AM
