TaoTao ATA250E Stator Cover install causes starter to turn slow
Old Apr 15, 2016 | 10:25 AM
misterddd's Avatar
Default TaoTao ATA250E Stator Cover install causes starter to turn slow
Replaced Stator, CDI and Coil. after removing and reinstalling the dry side cover the engine turns over slow, but if you loosen the mounting bolts on the right side it turns over fast again, all bolts were tight before and it turned over fine at normal fast speed, can't see any reason for this.
mounting gasket was torn but left in place. anyone have any idea why it would do this?
Now I can't tighten the side cover mounting bolts all the way down.
Thanks
Shooter71
1) Engine problems..
Sep 10, 2016 10:49 AM
gomer4877
Apr 13, 2016 09:25 AM
Shooter71
Apr 8, 2016 08:15 PM
Shooter71
Apr 8, 2016 08:02 PM
