Taotao 125d won't *stop* starting
Old Jun 4, 2016 | 12:00 PM
Adam.Lefkoff's Avatar
Default Taotao 125d won't *stop* starting
Hello, I bought a pair of taotao 125d's recently on eBay. Both worked fine for about a week, but then one developed a problem where the starter won't stop. As soon as the key is turned on, the atv will immediately turn over and even after the engine starts will continue to fire the solenoid starter. I replaced the solenoid and that didn't fix the problem. The starter switch on the left handle bar is also fine. This vehicle shouldn't be able to start unless the break is pressed down, so the issue is occurring somewhere "early" in the wiring from the ignition switch ? I read that a frayed wire could be in contact with the metal frame, but I haven't been able to find the problem. As soon as the key is turned, the back break light also goes on (as well as the atv starting) so perhaps that's a clue ? Any suggestions on where I can specifically look or things I can test to sort out this issue would be greatly appreciated. Cheers, Adam
Old Jun 5, 2016 | 01:18 PM
Zrock's Avatar
Super Quad Patrol
probably the only way to properly find the issue is strip the plastics off. This way you can see everything. Pull the power wire off your starter and just hook a test light to it so your not burning out the starter. I would start by unplugging the brake light and see if that helps (i have one that if the brake light is plugged in it will not start). Also while the test light is plugged in start wiggling and wires you may find the bad spot if the light flickers or goes out
Rdorr91
Mar 1, 2016 08:24 AM
Ride 4 Ever
Technical and How-To Articles
Jan 29, 2016 01:27 PM
60studehawk
Jan 18, 2016 11:07 AM
jmelton
Ask the Editor
Jan 7, 2016 06:58 PM
