Roketa 90cc Bogs Down
Old Sep 21, 2016 | 04:36 PM
celtictornado's Avatar
Default Roketa 90cc Bogs Down
My first post so be nice
I have a 90cc Roketa that bogs down under acceleration. Starts fine. Idles fine. Runs fine until you exceed half throttle. Steps taken: Changed plug a couple of times with NGK (black each time replaced), replaced air filter, rebuilt carb, moved c clip on throttle from 4th position to 3rd position, adjust idle and air adjusting 1 1/2-2 turns out. Still same problem. Any help would be greatly appreciated
Old Sep 22, 2016 | 09:15 AM
Zrock's Avatar
Super Quad Patrol
Still running to rich or you have the wrong temp of spark plug in. I could be wrong but i think carb adjustment should be about 2 1/4 turns out from lightly bottomed out.
Old Sep 22, 2016 | 09:18 AM
Thanks! I'm using an NGK C7HSA. And I will try your rec for adjustment.
Old Sep 22, 2016 | 01:24 PM
DirtDevil101's Avatar
I don't think A/F screw adjustments are going to buy you much at the throttle position mentioned...the more into the throttle the more you're onto the main jet...so I'd confirm the main and go from there. Are we sure it's a rich condition?? I'd run it at the fastest speed you can for 10 seconds then kill the engine...don't let up the throttle until you kill the engine (plug chop)...then pull your plug and tell us the condition or post pic...
Old Sep 22, 2016 | 02:41 PM
Okay...will try tonight or tomorrow. Thanks
Old Sep 23, 2016 | 09:26 AM
Zrock's Avatar
Super Quad Patrol
when you are moving the c clip are you moving it up or down? Going the wrong way will make it rich.
Old Sep 23, 2016 | 09:49 AM
I moved it to the middle. The last move was up
Old Sep 26, 2016 | 11:49 AM
*Update* Had no free time this weekend. Will try sometime this week
WilliamBos
Aug 10, 2016 03:59 PM
Timbo2500
Aug 2, 2016 08:22 AM
01sportsmna500
Jul 25, 2016 12:01 PM
Swariz
Jul 10, 2016 12:55 AM
