engine over rev
Old Oct 8, 2016 | 09:11 AM
Skip Smith's Avatar
Default engine over rev
Have a tao tao 110 for my kid. It starts but then revs like amaniac. I choke it down to slow the revs. Any idea what causes this. Unable to ride it just yet because of this problem
Old Oct 8, 2016 | 09:26 AM
Zrock's Avatar
Super Quad Patrol
Few things to check. Throttle cable for binding and proper routing. This will cause the slide to hang up. Vacuum leeks, and possibly carb cleaning
Old Oct 10, 2016 | 06:04 AM
Skip Smith's Avatar
Default over revs
checked the cables all move fine, took carb apart and cleaned. problem now is it won't start. have no spark at the plug. also think maybe the fuel and air mix are messed up. wish I had factory settings. but main problem now is the spark. I know I am getting fuel.
Old Nov 22, 2016 | 12:58 PM
Rasmaroon's Avatar
I think the carb has a plunger pipe-like with a needle at the end for regulating the fuel flow. Make sure that it's moving freely and that it goes freely ALL THE WAY down(up to the idle needle) when the throttle is at it's lowest. Also check if the spring is strong enough to push it down.
As for the spark(lack of) check your kill switches and spark plug.
jjgulley
Apr 27, 2017 08:24 AM
TheATVSuperStore.com
TheATVSuperStore
Nov 21, 2016 08:56 PM
Cameront23
Sep 12, 2016 09:26 PM
Ridingrulez8910
1) Engine problems..
Sep 10, 2016 09:21 AM
WilliamBos
Aug 10, 2016 03:59 PM
